Ana içeriğe geç
A GPS navigation device with a large touchscreen. TomTom’s all-in-one GPS navigation devices all include a touch screen, speaker, USB port, and an internal Lithium-ion battery.
20 Soru Tümünü görüntüle
Power cable hooked positive to negative, now does not power up
I made an adapter power cable, but I wired it backwards positive to negative. Now with a correct wired power cable the green light lights, but the unit will not power up when pushing the on/off switch. What component is most likely damaged and can I replace the damaged part?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try just holding the power button for 15 seconds. This is supposed to reset it. I can't find a schematic, so I can't pinpoint the most likely cause, but look for something burnt if holding the power button doesn't work.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
After my GPS sat for one day, pushing the power button at first did nothing. I hooked it up to the corrected power source and again pushed the power button and held it for 15 seconds. After just a few seconds the GPS came on normally. Thanks so much for your help. Frank
tarafından
Glad to help! Thanks for telling us how it went. So many times I wonder if people got their devices working.
tarafından
Yorum Ekle
Keep the polarity in electrical connections positive to positive and negative to negative when utilizing dc power. Connect hot to hot and negative to negative while working with Ac voltage
Puan 0
Yorum Ekle
Yanıtını ekle
fsandtb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 104
