My laptop screen is black and the fan won't turn on
When this happened, it suddenly turned off. I restarted it and it was on for a few minutes until it turned off again, and after that, when I turn it on, the screen is black.
When I turn on the laptop, the laptop makes a sound that it's starting to run and then it is silent. The fan isn't on, and the only light that is on is the power.
Bu iyi bir soru mu?
3 Yorum
Did you get it wet? Did anyone use it before you tried it when it powered off?
Brian Reeder tarafından
Cassandra Woods connect an external monitor and see if that displays your desktop.
oldturkey03 tarafından
You can also remove the battery and plug in the laptop using your adapter and then turn it on.
