Ana içeriğe geç
How to close the iPhone 6 properly
When replacing an iPhone 6 screen i have the following thing that botters me.
The iPhone on which i replaced the screen has a little 'space on the upper left side (on the height of the volume buttons) when its dark you see a little light. also if i push a little harder the screen goes a tiny bit down.
Question: Does this have to do with the way i click the screen in the phone?
Instruction video A shows: you have to click from top to bottom
instructoin vido B shows: once you placed it on the top, first click the bottem in and them slowly click the screen in upwards....
any advice?
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The iPhone 6 Frames are very prone to bending and warping which prevents the screen from sitting correctly, I have had this issue with the screen being raised slightly above the volume buttons a couple of times and a new frame has always resolved the issue.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Yes, after all this time I found this is the best solution. (Also bending the frame back, with the right equipment ofcourse, is a good solution to a slightly bent phone
tarafından
Yorum Ekle
En Yararlı Yanıt
Slide the top part in (so that the frame is under the outer frame of the phone), and then work your way down from there until the phone sits flush on all edges. Press hard and firm as it's not the easiest thing to get in there. Good luck bro!
Puan 3
Yorum Ekle
Yanıtını ekle
Alex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 93
