Bypassing google account in sony z5
How can i bypass the google account which was used in this phone earlier as i dont know that
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I assume the phone has just been factory reset and you are at the part in setup where it asks for the Google Account the phone was previously attached to? I'm actually trying to rescue a Note 5 from this same fate.
This is Android 5.1+ security at work, and there was a work-around using a custom apk and OTG cable, but that, as far as I verified yesterday (5/27) no longer works on Samsung devices, which says the part of the software used in the exploit has been patched. This may be the case for Sony devices, as well.
As far as I know, waiting 72 hours will allow you skip past it much more simply. I'm in the process of trying that with the Note 5 and can get back to you if you'd like. I assume the 72 hour lock is built in to allow time for the previous owner to report the phone lost or stolen.
Bu yanıt yardımcı oldu mu?
Hi i waited 4 days but still they ask for the google account which was in the phone earlier ((((( any progress in your situation ?
I'm going to be checking today, and I will get back to you.
@knirosh So, I just tried to set up the Note 5, still encountering the same issue. From what I'm seeing, everything points to having to contact the original owner to get past this unless a new work-around has surfaced (the device I'm working on has sat off and untouched for 4 days). Even tried wiping the cache partition from the recovery menu, no luck so far. I will keep working on it in my free time and if I come up with a solution, I will contact you.
I know how to bypass all samsung old and new frp email me here vro66rand&gmail.com
have same problem with sony z5 compact locked to a google account. tried to put in my google email and tells me locked to different account. help
Firmware newer than 06/2016?
Good luck bypassing FRP Lock a.k.a factory reset protection.
The only way after that is to either get original owner to remove it or flashing box if supported.
Iv baught a second hand z5 and it's doing it with me too, I don't know who the seller was as it was sold blind, what have I to do as just now I'm sitting with a £200 paperweight,
Done the same. Dont know the seller. if you find the answer would love too know as I also have a very expensive paperweight????
It didn't work for my phone but it might yours factory reset it you will need wifi go through language and wifi setup then when it says checking connections you disable wifi when it starts updating it will say error about wifi hit next it will bypass it to where you can put name time date and password. Now there are two different ways you can set up password continue through it till back at beginning restart then when it pops up password hit camera and will be able to access internet to bypass Google. If that don't work go do same I said earlier but instead if going through it until back at beginning stop when it says stuff about Google make sure wifi back on and hit one of blue words it will deny you if wifi still off it on it will take you to a long list choose any word and press on it until setup wizard pops up on bottom screen hit that go in and delete data for it go through rest stuff and should bypass it if that don't work go through it again and go to data usage it should have blue words above the graph you will be able to bypass to internet that way.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 23,481
4 Yorum
Hey Kasun, If you somehow forgot the gmail id or password of your google account, after hard reset you need to bypass the previous account. You can follow this guide to unlock FRP for Sony Z5: http://www.techoxygen.com/bypass-google-...
Kathrine Brooke tarafından
I reseted my Sony xperia e5 phone and I've forgotten my email to sign back in with and it won't let me back in
Kieron buckingham tarafından
Any advice for the Samsung galaxy J3 prime?
Patric tarafından
Here your Solution: https://frpapk.com/bypass-google-account...
Frp APK tarafından
