Ana içeriğe geç
Classique's 1600-watt hair dryer blows hot and cold air. Model: 087CQA. Made in Costa Rica and distributed by Western Wholesale, Oregon.
Why there is no air coming out from the Hairdryer?
it seems there is heat from the device but no Air coming out.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Little to no air comes out
Blockage
Examine the nozzle for any clear or easily removable blockages. There may be blockages which you cannot see, in which case, refer to this guide. Hair Dryer Nozzle Replacement
There may also be a buildup of hair or other particles in the grating behind the nozzle, in which case this guide will teach you how to replace it. Hair Dryer Grating Replacement
Wrong Setting
Verify that your hairdryer is set to a “High” setting and is not set to “Low.” In addition, you may want to engage the “Turbo” button to increase the rate of air flow.
Fan Problems
If no clear solutions present themselves, there is likely a problem with the fan/ motor assembly, which requires disassembly to replace. Refer to this guide. Hair Dryer Fan/ Motor Assembly Replacement
Hair Dryer Nozzle Görseli
Kılavuz
Zorluk:
Orta
1 minute
Hair Dryer Fan/ Motor Assembly Görseli
Kılavuz
Zorluk:
Orta
Hair Dryer Grating Görseli
Kılavuz
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Ali Alsulaiman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 367
