Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Soru Tümünü görüntüle
Green lines display in video and freezes frequently.
When video is played, or ichat is used green horizontal lines jump across the screen. Many times when using dashboard or switching to another app, the computer freezes and requires a reboot. This happens 5-10 times a day.
I'm thinking video card. Can you help?
Thanks,
David George
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Definitely sounds like a GPU problem. Check your computer to make sure it is not overheating. Overheating will cause the GPU chip soldering to develop fractures. Unfortunately there is no easy fix to this, you will have to get the GPU soldering reflowed or better yet reballed. But you must fix the overheating issues first or the problem will just keep coming back.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had this problem for a long time. In general smcFanControl software helps. It let's you speed up the fans to a point when the GPU is no longer overheating and the artifacts and freezes no longer happen.
Puan 0
Yorum Ekle
Yanıtını ekle
David George sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,480
