Ana içeriğe geç
Acer's 15.6 inch E5-571 series laptop manufactured in 2014.
Power switch isn't working?
Hi,
My Acer laptop isn't working anymore. When I press the power button, nothing happens. I looked inside the laptop and saw nothing strange on the power switch, also not on the flex. When I 'short' the connections from the power flex, the fan is working and the hdd runs; but nothing on the screen. After a few seconds is turns off. Could it be the power switch or is it something else?
Thanks in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Try taking it to a computer repair shop.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
sounds like there is more going on..
I had the same problem, turns out there was a ram problem to... it had a short circuit and fried the ram.
if the fan starts, there is power. maybe not enough, you ll have to check that. ( measure it out if possible)
than check with new ram.
if still not working :
check with an extern monitor.
Check the flat cable and connection from mainboard to screen.
it is possible the chip on the graphic card is fried..
I was thinking on a dead motherboard , but the fan starts ... so i think more in the other components..
Let us know,
Kind regards
Kevin
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Uas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 12
Her zaman: 618
