Location of the "Backlight Chip" on Sony Xperia Z5 e6653
Hi guys,
i replaced the screen from a sony Xperie Z5 E6653.
While testing the screen dimm dark and Backlight was disabled. LCD is working. If you look at very bright light you can see all things on the LCD but Backlight doenst work.
Anyone knows where is the backlight chip is located and any idea the fix this problem..
For Z3 and Z3 compact i'v found many intructions but for Z5 idont find anything.
No schematics, no manual no how to and no video for fixing Backlight issue on the Xperia Z5.
If you can answer with pistures were nice..
thanks a lot
Bu iyi bir soru mu?
have you found solution to the no backlight issue
festy019 tarafından
My z5 have the same problem.
Have you found solution to the no backlight issue?
korleis69 tarafından
korleis69, have you found solution to the no backlight issue?
h4p1n3ss44ll tarafından
did u find the backlight solution yet?
Has anyone found the backlight fuse location please?
RAYD tarafından
2 tane daha yorum göster
