replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
Bu iyi bir soru mu?
thanks
Bu iyi bir soru mu?
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
Bu yanıt yardımcı oldu mu?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 140
4 Yorum
or another more powerful, as the model a1229
davidegatt tarafından
Why do you think the logic board is broken?
mayer tarafından
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
