Why can't I get a image?
So I recently replaced my digitizer on my iPad 2 I think I did a good job and kept everything intact but when I went to turn it on I didn't get a picture and I tried re connecting the cables and everything still no image so I let the iPad sit and die down and went I plugged in the charger I get a image the battery which means it's dead so I know the lcd is intact and I let it charge up but still didn't get a image tried to do a hard reset but still no image I'm officially stuck
Bu iyi bir soru mu?
So the LCD shows display successfully because if you plug it in to charge it shows the low battery symbol and indicating that it is charging correct?
If this is the case then you will have to leave it charging longer. Make sure you are using a 2A charger and not a 1A charger which usually comes with iPhones.
Ben tarafından
