Cable replaced. Everything ok, but no screen. What could be the cause?
The cable that comes out of the back of my Apple Thunderbolt Display was fraying. I decided that rather than risk a short at some point, I'd preemptively replace the cable. Upon iFixit teardown photos, I decided to replace the cable that comes out of the back of the screen myself instead of paying nearly $200 to get an Apple Service Provider to do it here in Bangkok. Bought the cable on AliExpress for $12. Replaced it. And ... no dice. Screen did not come on.
My setup
[MacBook Air] ---- [Thunderbolt Display] --- [Thunderbolt drive] --- [Cinema Display]
with a USB drive and Ethernet plugged into the back of the Thunderbolt Display
Already tried
- Initial thoughts were that the cable was faulty. But then I noticed Ethernet came on, the USB drive was mounted, Thunderbolt drive was mounted and after a reboot the Cinema Display also come on. Obviously, the cable was working just fine.
- Second thought was that I had neglected to reconnect some cables that connect the LCD panel to the main logic board. I checked. Seemed just fine.
- Third was that perhaps the cable serial number was somehow tied to the main logic board. So I put the old cable back. Still no screen.
- Tried to connect the screen using an external Thunderbolt cable, everything worked equally well but still no image on the screen.
- Tried 30+ seconds and 3+ hours unplugged as a 'reset' of the screen. No change.
- Rebooted my laptop. No change.
- Plugged the Thunderbolt Display into the drive and then into the MacBook, so change the sequence of devices. No change.
- System Information reports under "Thunderbolt" the whole chain of devices, but under "Graphics/Displays" shows only the internal screen and Cinema Display.
- Using the newly-purchased cable as an external Thunderbolt cable works just fine too.
Question
Does anybody have any suggestions on what to try next?
Does the logic board go into some kind of lockdown mode when replacing the cable?
Are there more than 3 connecting flat cables + ground connection between the panel and the main logic board?
Although there is no reason to assume it has been, how do I test the LCD panel to still function given all these flat cable connectors?
Note: There are no Apple Stores here. Apple Authorised Service providers are no help. They suggested replacing the cable and the panel at a cost that is nearly the same as buying a new screen.
Bu iyi bir soru mu?
