Ana içeriğe geç
The ZTE Lever is a black 4G LTE smart phone sold in Wal-Mart stores with no contract and unlimited data. It comes with a front and rear facing 8MP camera. It was released on December 31st of 2014.
11 Soru Tümünü görüntüle
Is my battery faulty due to charging?
My phone currently is charging very slowly. I will turn the phone off while it charges for hours and it only charges maybe like an extra 10%. If I charge it while it's on, instead of charging up, it charges backwards if that makes sense. Also, it will only charge in a certain position. I've tried different chargers and even charged to different computers, and I still receive the same result .
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you have to position the charge cord in a certain position to get the phone to charge then the charge port likely has some pins that have broken in some area of the charge port. That could be why it charges with the cord in a certain position allowing the broken pins to make contact again which then results in the battery indicating charging. I would also assume with the pins being broken, even though they are making contact if held at a certain angle, would be the reason behind your slow charging issue due to resistance from the breaking point which is not allowing as much current through. I have repaired a ZTE Lever that was having the same type issues and it was broken pins in the charge port. So to fix it I had to replace the charge port which requires soldering as it is soldered to the motherboard. It may not hurt to check the battery too.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Azalea Buxton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 319
