Ana içeriğe geç
Phone won't turn on after battery replacement.
Hello there
Today I replaced my iPhone's front panel (backlight issues) and battery (didn't hold charge very well).
Everything went smoothly, more or less, but when i put it back together it didn't start up. I suspected the new battery was dead, but even after charging it for an hour it didn't seem to change anything.
Then i decided to disconnect the power ribbon and try turning it on while it's connected to a charger, which didn't work either.
However, when i connected the old battery it had booted up properly.
Is my new battery malfunctioning or am i missing something else entirely?
Note - with the new battery in the phone doesn't draw any power from chargers
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorumlar:
Okay, so i got another battery (different seller) and the same thing happens. Chances of getting two defective batteries in a row are kind of low so i'm suspecting the problem is on my end, somehow.
The phone charges normally on the old battery, so the charging port isn't broken or anything
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If the old battery is booting up fine then the issue will be with the new battery, probably a faulty part.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
sebastianflorkow sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 944
