Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Soru Tümünü görüntüle
MacBook Case screw won t turn! what can I do?
retina 13-inch early 2015
Hi,
So yesterday morning i spill some coffee on my macbook, screen went black and stop. So i quickly unplug it and begin to open the case. When i did manage to open the case and clean the component inside, let it dry 24h and reassemble it.
It works when plug to the power supply, and it seems the battery is dead.
I want to replace it, with the kit on ifixit. My problem is 3 screw won t turn anymore with my screwdriver. And now i am stuck with a case that i cannot open.
What should i do ?
Thanks your help.
E
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Those are T5 screws in this guide:
MacBook Pro 13" Retina Display Early 2015 Battery Replacement
I would use a better driver with a top that swivels so you can press down on it with the thumb or palm of one hand and turn the body of the driver with the other. Also got for the screws that you are having problems with first leaving the others ones in to try to relieve any possible pressure on the bound screws. Here's the type of driver I use for this: T5 Torx Screwdriver
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
enis al sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 753
