Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Home button not working after battery replacement - Touch ID still is
Hello,
I recently replaced my battery in my iPhone 5S however the home button does no longer work. Touch ID is still fully working however Does anyone know why this is?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
تحتاج الى تغير زر الهوم المنزل ولكن لابد ان تأخذ بالاعتبار ان عند تغير زر الهوم ستفقد خاصية البصمة
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
It's means you have partially ripped / damaged the home button ribbon cable assembly.
Unfortunately the only option is to either get it repaired or replace the home button but without touchid functionality as the home button that comes with the phone is linked to the board.
Puan 2
Yorum Ekle
You could have very well damaged the home button cable during the repair. Even a microtear in the cable can cause the home button to malfunction.
Also keep in mind that home buttons have a rubber gasket around them. This gasket is very similar to other gaskets (ie engine gasket) that sometimes need to be replaced during the repair due to general wear and tear.
If the home button does not click properly, try readjusting it or replacing the gasket. If your home button in fact did get damaged during the repair, replacing it is simple, but you will not have any touch id afterwards because home buttons are married to the motherboard inside your phone. If they are not able to talk to eachother anymore, then you will not have the touchid option available.
Puan 1
Yorum Ekle
There are several reasons for this problem for example pry damage, a malfunctioning lightning port and so on. You should troubleshot the problem by following this guide: How to Fix iPhone Home Button Not Working after Battery Replacement
Puan 0
Yorum Ekle
Yanıtını ekle
Skinless Gaming sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,957
