Why is my ds lite not reading cartridges I put in it?
My ds lite is not reading the ds or game boy advance cartridges I put in the slots.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
you may have corrosion on the copper pins in each slot. To fix this, gently apply rubbing alcohol to the corroded pins with a cotton swab. Although it is unlikely that both of the slots would have this problem, it is worth a shot.
Bu yanıt yardımcı oldu mu?
If the above doesn't help get rid of the corrosion, try this. Get a sheet of 600 grit wet-dry sandpaper and use that to lightly sand the metal contacts.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 487
