Controller battery won't charge
The battery in the controller won't accept a charge. When I plug in the charger I can turn the controller on, but it won't charge, even when left plugged in for hours. Also, when plugged in and turned on, the red light next to the four white lights is illuminated. I'm guessing the battery is bad. How do I replace the battery?
Bu iyi bir soru mu?
6 Yorum
I have the exact same problem. I have only used it once!!
Derek Scott tarafından Paylaş
I'm in the same boat however, mine will flash the one led for a few moments and then will stop.
manchesterman96 tarafından Paylaş
Same problem with my phantom 4 RC. Send to repair, happen again after 1 month.
BT LOH tarafından Paylaş
Just wanting to know PS, XBox, Nintendo Wii etc... and when it is plugged in, does the controller work normally when it is plugged in? Can you play if controller is plugged in?
sirozmonster tarafından Paylaş
Yes. Does this mean it is simply a bad battery?
Charlie Gaines tarafından Paylaş
1 tane daha yorum göster
