Ana içeriğe geç
Won't spin after I changed the belt
I have a heavy-duty Kenmore 70 series washer that I replaced a broken belt. I've put it back together and now it won't spin though it sounds like the motor is spinning the drum and agitator don't. Some oil did leak out of gear box
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Most Frequent Causes for Vacuum cleaner belt keeps breaking
Cause 1
Brushroll
If too much hair, string, or lint is caught in the brushroll, the brushroll can get stuck. If the brushroll is stuck, it will put too much strain on the belt and may cause the belt to break. Remove the brushroll and clean out any debris from the bearings. After replacing the brushroll, make sure that it turns freely.
'''Most Frequent Causes for Vacuum cleaner brush not spinning
Cause 1'''
Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the vacuum cleaner belt is broken or stretched out, replace it.
Cause 2
Drive Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the drive belt is broken or stretched out, replace it.
Cause 3
Cogged Belt
Inspect the belt to see if it is broken, stretched out, or out of place. If the cogged belt is broken or stretched out, replace it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Are you sure hat the belt is on correctly as it sounds as if the tensioner is not doing it's job.
Puan 0
Yorum Ekle
Yanıtını ekle
Leo Abad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 1,261
