Ana içeriğe geç
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
My headphones broke inside my iPod how do I get it out?
I went to take out my headphones and the tip broke off inside my iPod and now I have no way of listening to anything the sound does not work.... I need help ASAP!!!
Bu iyi bir soru mu?
Puan 2
1 Yorum
Never get a cracked screen protector from a phone and cut it out on an iPod nano 4th gen and you dropped it my screen cracked bad and I had to peel off the screen and now there is nothing protecting the screen. When that happens you should buy a IPod Touch 6 gen if your old ipod breaks just in case if it breaks.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Alright cheeseman ;>), here's an upvote!
Also this tool is pretty handy.
GripStick Headphone Plug Extraction Tool
GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacks Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Use a very powerful magnet and a pair of pliers. Have something hold the iPod upright with a magnet in one hand and pliers in the other. Get the magnet to pull it out partway then grab it with the pliers. If that doesn't fix it, use ifixit's teardown to get the back case off. Once it's off, there should be an opening at the back of the headphone jack you can put a toothpick through. Put a toothpick in the hole and push it out. Hope this helps!
Puan 1
3 Yorum:
Did this answer the question? Did it help?
tarafından
I'm pretty sure a VERY POWERFUL magnet would mess up wires/metal parts in the iPod.
tarafından
Probably not.
tarafından
Yorum Ekle
Try using a vacuum cleaner otherwise m, You may have to get the part replaced.
Puan 0
1 Yorum:
Lmao a vaccum cleaner?
tarafından
Yorum Ekle
Yanıtını ekle
aaliyah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 251
