Ana içeriğe geç
Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
62 Soru Tümünü görüntüle
Why does motor now runs backwards?
Why does a electric motor run in opposite direction now ? 220 Volt Motor is on my Sears saw.
Motor can be run on 110 volts or 220. I have always run this on 220 volts for 40 years,
yes 40 and I still have all my fingers to count on!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Not all electrical motors can run in both directions, but most will run the other direction if the positive and negative connections are switched.
So I would try to switch the positive and negative power connections to the motor, and see if that helps.
I am however not an electrical engineer, and by no means an expert, so try at your own risk!
220V is dangerous, and CAN KILL YOU.
Don't mess with it unless you know what you are doing.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
bill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 115
