Re the stuck home button: loosen the two screws that hold the bracket to the back of the home button. By ¼ of a turn. Then test and adjust.
Re the water damaged phone: from experience, in most cases I don't spend time and money on phones that had liquid damage. I do it to try and recover data. But for saving the phone (the hardware), it is far from efficient. Water is invasive, it will go beneath all the chips and to all the solder joints and start corroding them. Specially pool water which could be saline or chlorinated.
Once the board dries, corrosion sets in and starts wrecking havoc on the board.
If the phone did work after it dried, it is likely to fail soon after. You start loosing functions like display, backlight, touch, service,Wi-Fi, sound, etc.
However, if you do wish to retain and fix a water damaged phone, the minimum is to take the board out, soak it in IPA at 99%, brush and air dry. This is far from ideal, since corrosion is still occurring under the shields.
A better solution is to remove the shields from the board, and do the IPA treatment.
The best solution is to remove the shields then clean the board in a pro sweep ultrasonic cleaner and then do the IPA treatment. Currently, this is the best solution we know to stop and remove corrosion even from under certain chips.
This however does not restore the missing solder and strength to the joints which will fail at the slightest stress.
We do fix water damaged phones sometimes for the sake of the device. When it looks like the damage is minimal and there is hope that the board's integrity is not highly compromised; and never offer warranty to the customer. Which sucks for them if they pay money and get an often soon to fail device.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum
What would the screws do? I've tried it with and without the screws in the logic board.
Steven tarafından
