repair and maintainance of nokia 1218 with the procedure
The phone fall in water
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@abujabir waiting for it to dry will leave it to corrode and die a slow death. If you are thinking about placing it in Rice or equivalent, forget it. Rice does not do anything. You will have to treat this like any other device that was submerged.
I strongly recommend that you clean it. Disassemble it and clean it properly using this guide. It was written for an Apple iPhone 3G but all the points still apply to your phone as well. Once it is properly cleaned '''replace the battery" reassemble and re-evaluate. With a new battery and properly cleaned, you will have a good starting point should any further trouble shooting be necessary. I seem to have trouble with identifying your model. Double check your make and model and let us know what it is so we can try and help you further.
Bu yanıt yardımcı oldu mu?
The best you can do now is just let it dry and see if it turns on.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 63
