Ana içeriğe geç
Why won't loudspeaker work?
I recently dropped my phone in water, I was able to dry it out and at first the loudspeaker worked but it was very quiet. Then it completely stopped working, so I replaced the loudspeaker. Still didn't work, I thought maybe it was some corrosion on the connections on the charging port, so I cleaned them and still nothing. Now I replaced the charging port and a new speaker and still nothing. What could be causing the loudspeaker to not function?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello chsash08 ,
Clean the FPC connectors by isopropyl alcohol and check again.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I have tried cleaning with isopropyl alcohol and still nothing. I should add no sound comes out of aftermarket speakers and only a faint sound comes out of the original.
tarafından
There is probably still some water damage / corrosion on the logic board under the metal plates. I suggest getting it checked by a professional mobile phone technician that does board level repairs for iPhone.
tarafından
Ok I'll try that thank you
tarafından
Yorum Ekle
Yanıtını ekle
chsash08 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 132
