Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazı tamir ederken daha önceki modellerde kullanılan aynı tornavida ve plastik açma araçları gereklidir. GSM/CDMA olarak, 16,32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renkli modelleri mevcuttur.
3871 Soru Tümünü görüntüle
Lower speaker sometimes work
Hi!
I have recently changed my sisters iPhone 5S (My old phone) to one of does fancy styling backplates to "iPhone 6 Mini" design. and after that the lower speaker only works a few seconds after reassembly...
When the screen is not pressed down in the housing the speaker works and several restarts, still working. After the screen is pressed into place the speaker still works but then later shorts out... Then the speaker works with the screen just been pressed down I can even restart it and then a little later the same thing...
I have tried taping the visible metal on top of the speaker with electrical tape but no luck..
Anyone had a similar problem?
Best Regards
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
iPhone Pil Tamir Setleri
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Cevap
Filtre ölçütü:
Have you checked to make sure all ground are connected and or getting good connections
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
The speaker connects via a pressure connection to the dock connector cable, so either something is not holding it tight to the contacts, or the prongs on the speaker are bent or damaged. Be super careful bending the prongs, as they are extremely thin and will break easily.
tarafından
Yorum Ekle
Yanıtını ekle
Miki Kristiansen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 24
