What is my laptop's power problem?
I plugged my power adapter to charge the laptop. The red led came up indicating charging. I expected it to turn green after four hours indicating fully charged but it won't, so I put on the system to checked the charged percentage. To my surprise, THE GREEN LED FOR POWER ON AND NUMBER LOCK CAME UP, THE COOLING FAN START WORKING BUT THE SCREEN DIDN'T DISPLAY.
I detach the power adapter from the laptop and immediately the system went off SIGNIFYING THAT THE BATTERY ISN'T CHARGED AT ALL.
I tried putting the system on without plugging the adapter but it won't come up. I plugged the adapter and put on the system, it was on but no display. The charging led was on as well. I removed the battery without unplugging the adapter. The system remained on but the charge led went off. I reinserted the battery, the charging led came up again. I left the system like that, on but no display, for another two hours after which I removed the adapter and immediately the system went off.
ANY HELP PLEASE?
Bu iyi bir soru mu?
4 Yorum
Hi,
What happens when you remove the battery and plug in the adapter and then try to start the laptop?
jayeff tarafından
The system powered on but no display still
Olusegun John KEHINDE tarafından
Hi, Can you connect an external monitor and see if you get a display?
jayeff tarafından
The display is now working. I refix the display flex and the display came up. The battery signal indicate charging but remained 0%
