HDMI input on my 4k LG not working
LG flat screen 55uf645
My inputs
Is not working it said check I puts
Update (08/30/2016)
Yes tried all HDMI ports 4k only works on hdmi1
Bu iyi bir soru mu?
My inputs
Bu iyi bir soru mu?
Try removing all HDMI cables and then "remove" the power cord for about 10 minutes (powering off is not sufficient ). Then Plug in the power cord, then one HDMI cable and try your device that way.
Also, something to note there is a known flaw with these tv's that cause a spike on the motherboard that cause the HDMI ports to stop working altogether.
http://www.lg.com/us/tvs/lg-55UF6450-4k-...
Look under ratings and reviews.
Hopefully the reset will get you backup and running though.
The board replacement is not hard either though.
Bu yanıt yardımcı oldu mu?
Thanks, the powering off for a few mins worked.
The solution sounds crazy but remove the main board and bake it in the oven to allow the weak solder joints to reflow, it will normally last about a year or two depending on use, when they go out again, repeat.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 33,728
3 Yorum
Hi,
Can you prove that the device(s) that you wish to connect to your TV using a HDMI connection are working via HDMI by connecting to another TV? Have you tried using a different HDMI cable? have you tried all the HDMI connections on your TV?
jayeff tarafından
yes used different TV, New HDMI cable, tries ALL three HDMI ports
Larry tarafından
can HDMI board be replaced
Larry tarafından
