Ana içeriğe geç
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, and a better design.
290 Soru Tümünü görüntüle
Why does my L button not click and jam somtimes?
I am currently playing Monster Hunter Generations and the L button is very important. Since my L button doesn't click any more it just gets held down and gets me killed/makes me the biggest liability to my team. It also gets jammed sometimes but so far that is easy to fix with a can of wd40 and or air. Please help me to fix this I think i already know how but I would like to not do any thing without getting all the input (hehe) I can
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
iPhone Pil Tamir Setleri
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Since you've already told us that the 'L' button is the most import button for this game. It sounds as though it may be worn out from repeated use. It happens very frequently and the button can easily lose the "click" feature. This link is of a DS Lite Shoulder button I broke down to inspect but it has primarily the same features in your 3DS XL. The second item is a little convex metal disk that "clicks" when you press down on it and springs back up. When it clicks, it makes contact with all the metal pins in the housing and sends the proper signals to the game. When it wears out, it can either be dented or flattened to far.
The jamming could be a combination of not springing back up properly and either a couple different possibilities: the spring is rusty, there is too much dirt/gunk/debre holding it down, a dent could cause the plastic to hold it in place too. There are a multitude of various reasons why it's getting stuck.
To fix all of this, your best bet is to order a new 'L' shoulder flex ribbon off eBay and get a small phillips head (#000 size) screwdriver to open it up. Once open, clean your shoulder button area with rubbing alcohol and replace the flex ribbon. You can follow this guide to accomplish it: Nintendo 3DS XL IR Board Replacement to step 8 then just remove the plastic and such to get at the ribbon. Be careful not to lose the pivot pin or spring when removing those items.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
mross1129 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 20
Son 30 Gün: 74
Her zaman: 700
