Ana içeriğe geç
Model A1199 / 2, 4, or 8 GB capacity
100 Soru Tümünü görüntüle
Can I get the stripped screw out?
Appears the screw is stripped or I just can't get Enough of it to get it out (tiny screw nearest edge of Ipod case) apparently not uncommon as instructions warn of this but no solution for how to solve it when it happens any ideas? Should I try to find an even smaller screwdriver, not sure it would matter
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Hemen Alışveriş Yapın
iPhone X Fix Kits
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Put a little super glue on the screwdriver end and press it onto the screw. Hold it there for about 15-30 mins. Try to take it out.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
so before anyone responded i was able to find a #000 screwdriver which helped and i was able to get the screw out and i moved on to the next screw (step 7) which was deeper in the case. i am not able to get this screw out either. So i did try the super glue trick and but this didnt work for me, i could possibly try it again ?? but now i am wondering if i really need this screw to be removed? ha ha trying to find a workaround i guess i am running out of options ..
tarafından
That's a #00 screw, use a bigger screwdriver.
tarafından
thank you for your help i tried that as well without success.
tarafından
Try a #0 or a #1, maybe that will work.
tarafından
i already did .. its butted up against the case so much there is no room for anything there probably glued the screw in place by now ... i am calling this a fail. thank alot for all your help.
tarafından
Yorum Ekle
Yanıtını ekle
Lori Baldridge sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 266
