Can I remove the sensor cable to disable the front camera?
In this step, the front-facing camera and sensor cable are disconnected.
I would like to know if the front camera is able to function without this cable being connected. I would like to disable my front camera.
Bu iyi bir soru mu?
4 Yorum
Apparently the phone will be stuck at the apple logo if the sensor cable is not connected. Is this supposed to be the case ?
Daylen tarafından
I think it will be best if u didn't do that and an expert did cause like u
can get electrified and that could lead u to certain death cause I have seen this happen
LOLA tarafından
Ummm..... The battery is only about 4 volts.... You can't get killed by this unless you stab the battery repeatedly with a knife and it blows up...
Gigabit87898 tarafından
LOLA has seen people be electrocuted by a phone? I've shocked myself more times than I can count. Heck...you can't even feel the low voltage on a phone.
OP: I wouldn't disconnect the whole cable. Besides the errors it could throw, your screen would be on all the time on calls. Its annoying.
Josh W tarafından
