iPhone Reboot loop with blue patch
I just removed my rear camera following ifixit's guide and everything is working so far.
I lost one of those 1.7mm screws for the metal bracket, but it still works properly until 2 hours ago, when it shutdown by itself and is stuck in a reboot loop with a blue patch that covers 70% of the screen, originating from the middle.
Is there anyway to save my iPhone ? Will buying the missing 1.7mm screw help ?
I doubt it is a misplacement of screws as my phone is able to work till 2 hours ago.
Regards,
Lost Soul
Bu iyi bir soru mu?
Did you try re-opening your phone to see if anything was knocked loose? Those brackets hold the press connectors in place, so if it wasn't entirely screwed down then it would be more likely that one of them could be disconnected.
Paige Reisman tarafından
I re-opened the phone and found that the 3 connectors beneath the bracket (Digitizer, LCD, Sensor) is connected to its respective sockets. I reseated all connectors but the issue still occurs randomly. Sometimes it can be working fine for a few hours, and then the reboot loop strikes again. Guess I will buy the iPhone 5S screw set and replace that particular 1.7mm screw and hope it solves the problem..
Daylen tarafından
