Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
Why can't you buy a 6s digitizer without the LCD?
Hello. I'm new to repairing phones, so this may be a silly question, but why is it so difficult to buy the iPhone 6s digitizer without the LCD?
I've replaced a broken screen on an old iPhone 3GS, and the replacement digitizer I bought didn't have the LCD attached, I had to transfer it from the old display.
I would imagine that a digitizer without an LCD would be substantially cheaper than one with the LCD, so why can't I find any? Is it impossible to remove the LCD in the 6s? Is there a time period after a new iPhone is released in which you can't buy the digitizer separately? Or is there some other reason?
Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is no digitizer, the touch function is built into the LCD panel.
The front glass is just glass, and it is directly bonded onto the LCD. It's not like iPhone 3GS that there are separate pieces. Unless you have the expensive equipment to peel the glass off and risk cracking the LCD every time, it is not possible to separate them.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
While Tom is basically right, he's not technically right.
There is a separate digitizer for the iPhone 6s. However, its bonded onto the LCD. You can peel it off if you try hard enough. However, the problem is getting a new digitizer on the LCD. The digi is bonded onto the LCD. It is possible that you could use some sort of heat stamping method to get the new digi on, but you have no way of getting it lined up. The process used to line up and bond the digi to the LCD involves a machine that uses x-rays and sometimes lasers to line everything up down to the fraction of a mm. It then bonds it in a special process.
So the quick answer is yes, you could save yourself the extra $30 that a screen with a digi attached would cost. But it would cost about $5,000 in machinery and I don't know how long in time to acquire the skill to get things right.
Puan 0
2 Yorum:
Well, iphone 4 and 4s has this kind of 3-layer design, LCD (display cable attached)+digitizer (touch cable attached)+front glass. Since iphone 5, the standalone digitizer is elimitated, the touch sensors are built right into the LCD, there is only LCD+glass.
tarafından
take a look at an iPhone 5+ LCD. You'll see there is one cable for digi, one for LCD. Follow the digi cable back to the LCD and you can peel that connector off. Grab a razor and you can peel the digi off.
Like I said...you were right. But sometimes when troubleshooting a touch issue, its important to know that the LCD and digi are 2 different things and can malfunction independent of each other.
tarafından
Yorum Ekle
Everyone's right except I have done this repair and replaced glass only...while it wasn't the easiest thing I heated it up and used a super thin metal wire and fishing line to separate the glass from the glue then I used one of theseHere= to line the new glass up the apply LOCA UV glue which has to be cured by uv light but once cured your ready to install So THERE IS NO NEED FOR $5000 IN EQUIPMENT
Puan 0
Yorum Ekle
I'm guessing its because of the 3D Touch layer on the iPhone 6s.
Puan -1
Yorum Ekle
Yanıtını ekle
Michael Sligo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 262
