I have error code 32
I have error code 32. My tv will not even turn on just the indicator light flashing yellow for the lamp.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hello, hizeada. Error code 32 corresponds with an open lamp cover. If your lamp cover is in fact closed, then chances are the lamp cover is either not installed properly or the lamp door switch simply isn't working. You can try to troubleshoot this by removing both the lamp cover and the entire rear cover. First, check the operation of the switch. You want to ensure that the long lever part of the switch is not broken and is in the correct position to make contact with the lamp cover when everything is reassembled. If the switch seems to be in good condition, go ahead and reinstall the rear cover and lamp cover and check to see if you are still getting the same error.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 911
1 Yorum
hizeada what model is your TV and what have you checked?
oldturkey03 tarafından
