Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
452 Soru Tümünü görüntüle
Will not turn on or charge - What to check first
I have a used iPad 4 it will not turn on, will not show charging, will not connect to PC.
looking for the best suggestion as what to check first?
I would think it's the battery htt I am open to suggestions of things to check before I replace it.
Thanks for your input
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
RJ. I Pad will fail to turn on if its battery is completely dead, check battery and charger if you can or have a Tech. check it.
Maybe try this first, try a hard reset which may get you up and running again. To see how to do this and other trouble shooting info. check the attached links.
http://www.howtogeek.com/216839/what-to-...
https://support.apple.com/en-us/HT201412
http://appletoolbox.com/2014/12/ipad-wil...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
RJHATTON sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 76
