Tips for making the screens fit better?
Hello!
I work in a shop where we repair a lot of iPhone 6. However, for some reason I still can't put my finger on, many screens doesn't fit properly. This often is due to the housing being bent or corners having dents, but also when the frame is perfect or near perfect the screens tends to be somewhat loose on one or both sides. Particularly on the upper left side by the mute button.
Sometimes this can be remedied with adhesive but I'd much rather do it properly if you guys have some general tips for fitting the screens.
Also, this happens with any quality. We use mid and high quality screens. It's less frequent with the high quality ones though.
Bu iyi bir soru mu?
2 Yorum
When a iPhone 6 comes in with the screen cracked, you can bet the frame of the iPhone's metal housing has become deformed slightly in a way at least (from dropping / physical damage) and probably won't let the screen sit like perfect so easily in some cases.
Ben tarafından
Yeah, of course. We use tools and files and good ol' finger muscles to bend the housing back into shape. Even though I often deem the result very good, it seems that the slightest deformity prevents the screen from fitting, often in the upper left area like I said, which sometimes makes the backlight shine through between the screen and housing. A very sore sight.
However I've been wondering if there are particular areas of the screen itself that is known to be off-shape which you could file down for better fitting or some such.
Pwny tarafından
