lenovo yoga tablet 2 suddenly won't charge or open
Hello! I got my Lenovo tablet 2-1050F ( Mfg Date: 2014-12-23) in January of 2015 , I wasn't frequently getting on my tablet more than once every 3 day and sometimes I decide to use it and I find that the battery is empty, while there were no applications left open that may cause the battery discharge. Today and after three days of non-use the Tablet... I found the battery empty, I plugged in the original charger but nothing worked even the light around the Bush button key.
I searched the Internet looking for a solution and I have followed the steps showed below but it has completely failed
1. Plug the power adapter into the Tablet
2. With the adapter plugged in, Hold down the power button for 20 seconds
3. Disconnect the power adapter from the Tablet and press the power button for 20 seconds.
4. Reconnect the power adapter and turn on the Tablet. It should power up just fine.
Please any other help rendered shall be of high importance
Bu iyi bir soru mu?
22 Yorum
I had the same problem. Followed just step 3 and 4 which made the tablet turned on. It showed 73% battery charge left on the tablet and was able to proceed to login. So it worked for me.
Alfred Teng tarafından
My Yoga 2 (2014) was on standby overnight and crashed. Zero battery all next day, refused to charge, did power on power off, ran check up, ect, no good. Now just did steps 3 and 4 above and to my surprise it's charging. Can see it's working by power monitor plus wall power pack is heating up per normal. I suspect battery voltage was abnormally low and charger was confused but what does holding power button for 20 sec do?
grahamandjenny tarafından
I have a Yoga Tablet SG3 Black, I tried this, and I know it's not a Yoga Tablet 3, but it just showed this code, and I don't know what to do, please help.
Josh Chakravarty tarafından
When it occurred again I on-line chatted with Lenovo and they had me update some drivers and BIOS - great now.
Hello, i have a problem with my lenovo yoga tab8 , its reeboot when i whant to charge or when i connect to the pc , it dont stop, its reboot and reboot, on the screen its writen tool dl image file! and i cant connect with my pc to solve with sp flash , please help ....
maskadu tarafından
17 tane daha yorum göster
