Ana içeriğe geç
Can we recover electronic device Drenched in shampoo?
My TABLET device got drenched in shampoo is there anyway to recover my device and make it work again /
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
As you know liquids and electronics and electricity are not a good mix.
Any liquid causes corrosion and provides circuit paths for the electricity which were not in the tablet's operating design and could damage the components.
First you need to remove the battery from the tablet. You may have to search on You Tube for videos on how to open your tablet. Even a video for a 'generic' brand of tablet may be useful if you cannot find one for your particular make and model. The sooner you remove the battery the less damage will be inflicted.
Then you need to dis-assemble the tablet and clean all the parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and in your case shampoo.
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from liquid damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the tablet might possibly work correctly again
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
how do i do this!? in an accident some shampoo (tesco exclusive apple) might have gotten in my tablet (huawei matepad t8) (at most should be about 1-5 ml that gotten in please help me i'm panicking (note i'm only 11)
tarafından
@Heng Jia He
Here's a teardown video that shows how to open the tablet so that the battery can be disconnected and the systemboard cleaned using IPA99%+etc.
If you have never done this before then it will be difficult for you to do and you may damage the tablet even further when trying to open it and fix it.
Contacting a reputable, professional mobile phone repair service experienced in liquid damage repair may be the best option for you.
tarafından
Yorum Ekle
Yanıtını ekle
Srinivasan Thirunavukkarasu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 388
