Ana içeriğe geç
Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
22 Soru Tümünü görüntüle
Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Bu iyi bir soru mu?
Puan 2
3 Yorum
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
tarafından
Re-aligning print heads doesn't solve the problem....
tarafından
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Puan 0
Yorum Ekle
Yanıtını ekle
Khemchand Ramcharan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 44
Her zaman: 4,027
