Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Bu yanıt yardımcı oldu mu?
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 43
Her zaman: 4,026
3 Yorum
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
Khemchand Ramcharan tarafından
Re-aligning print heads doesn't solve the problem....
Tracy Lloyd tarafından
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
jayeff tarafından
