Ana içeriğe geç
Why logic board chimes when pin is touched with probe?
Hello Guys,
Maybe one of you can help with this unusually weird problem I have with my 820-2330 logic board. The board powers on, but won't chime or boot until I touch a couple of specific pins on chip U8900. This is what happens exactly; when the board is powered on and I touch pins VO or OCSET on U8900 the board then chimes and boots normally. It is driving me crazy trying to figure this one out. At first I replaced U8900, then I replaced both FETS, then I replaced the Critical caps after the inductor all to no avail. Any help would be appreciated.
Thanks,
Roger
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Look for an open trace or bad component attached to one or both of the pins you mentioned. If an input pin is not connected, touching it with a logic or scope probe connects it to ground through the probe circuit, thereby giving it a logic low (“0”)signal.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Roger sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 54
