changed battery then the phone won't work ever
my battery was so bad then i changed it after that the phone dose not working at all
even thou i tried to check the cables still not working ,! plz help maybe the screen problem
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Check that the battery cable is properly connected and that the connectors on the cable and logic board are damaged. Also, check all the other cables and connectors on the logic board. It's also possible you received a defective battery. Try plugging it into iTunes, if iTunes can see it then it's most likely just that the display is improperly connected.
Bu yanıt yardımcı oldu mu?
thankyou for your help . i have tried what you said but still nothing new. maybe something else get wrong or damaged
and now my phone is working on iTunes but the screen doesn't altho it is not damaged i think the first connecter is damaged how can i check
Check the gold pins on the connector. If some appear to be bent or damaged then that's your problem. The display could have broken in a way that isn't visible.
How do you removed the battery? Sometimes you can get an pry damage with batterys change
it works but there is no display
Yes but sometimes batterys are not well removed and people press the board with wrong tools.
Batterys should always be removed from the opposite side of LogicBoard.
Can you test another display?
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 91
