Ana içeriğe geç
Acer Iconia One 7, Nisan 2014'te piyasaya sürülen bir tablettir. Iconia One 7, medya eğlencesiyle dolu kompakt bir pakettir. Hem net hem de renkli, phablet'ten daha büyük bir ekranla, işlerinizi sürdürmeniz için hızlı tepki süresi ve saatlerce pil kullanım süresi elde edersiniz. Ayrıca, ebeveynlerin kontrol edebileceği birçok harika çocuk içeriği barındıran Kids Center platformumuzu da dahil ettik.
black screen - can't use it.
hello everyone,
I just needed some help with my Acer Iconia one 7 B1-770. I hit the display brightness/darkness at its minimum and found out I can't see nothing at all. I thought there might be issues with low battery but when I pressed the volume, I could hear any sound. Unfortunately, I cannot use my tablet anymore.
Does anyone could help me how to fix this issue??please.
Thanks & God bless.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Hello, have you tried a factory reset? Follow these steps:
1. Power off the tablet.
2. Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3. While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4. Once the tablet screen turns on, stop holding the buttons.
5. On the Android system recovery screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
6. When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
7. Select reboot system now.
tarafından
My acer 10 tablet was stuck in black screen after disabling the boot from boot option properties. didn't start up the windows after turning it on.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
I had a friend bring this issue to me…
turns out the brightness was just down to zero..
so pull down from the top of the tablet twice.
then about 1 and a half centimeters down just try to use your finger and catch the brightness slider and slide it to the right again and voila… working again.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
How to fix my acer ipad black screen with grey lines
Puan 0
Yorum Ekle
Yanıtını ekle
Renalie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 5,500
