Ana içeriğe geç
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
118 Soru Tümünü görüntüle
How do I fix a loose charging port?
I have a problem that you might be able to help me with. My phone USB port I think that's what it's called well is loose and my phone doesn't charge well it charges very slowly but I have to maneuver around the cord is there anything I can do to fix it
Bu iyi bir soru mu?
Puan 6
2 Yorum
I had this problem too. The solution was to buy a new good quality charger. It's probably not the device but the plug.
tarafından
my dad has a alcatel one touch and we had to hold the charger in the phone and now it will not charge no more what is wrong
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Briggette, sounds like charging port is warn/damaged, you may need a new port. Drop into any small computer/cell phone repair shop and have them take a look,diagnose and estimate repair. I will post a link for you to see how the port is changed if you would like to try and change yourself.
Check the attached link,instruction and guide, Good luck
https://www.youtube.com/watch?v=VQekmZQr...
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
Can you use any charger port or does it have to be from the same kind of phone
tarafından
Yorum Ekle
Broken port most likely .
Puan 0
1 Yorum:
Mine broke going in to charge almost like they werwnr seated properly inside the tablet cuz I felt it go further inside which made it impossible to make connection to charge at all without breaking it open fig out why it came loose and I read some place it's a known issue no less good times lol
tarafından
Yorum Ekle
Yanıtını ekle
Briggette Gonzalez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 29,656
