Ana içeriğe geç
Broken screen - touch function didn't work before or after repair
Hi,
I'm repairing an iPod 3rd Gen that came to me with a broken screen. The touch aspect didn't work.
After replacing the screen/digitizer, the touch aspect still doesn't work. I've double and triple-checked the cable and am pretty sure I have it in right.
I have also tried hard resetting, restoring, multiple times.
Any help?
Thanks in advance.
Bu iyi bir soru mu?
Puan 1
1 Yorum
I just gave up... nothing I could find. I assume the drop damaged the logic board.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the touch screen doesn't work, then either the digitizer is broken, or the connection is bad, or the logic board is broken.
If you've already tried replacing the digitizer, then disconnect the cable and examine the connector on the logic board with magnification, and see if you see anything you can fix. If not, then you'll have to replace the logic board.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
spacec0w sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,133
