Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Soru Tümünü görüntüle
Replaced complete screen replacement now screen is unresponsive
Replaced screen digitizer and LCD and now screen is unresponsive once closed all the way but when open it works. Can you tell me what to do or what could be wrong.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Did you ever get this figured out? I'm having the same problem.
tarafından
If you want to get answers, please post this as a new question.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Pull the screen and make sure the connection are clean and secure. Also, make sure there isn't anything on the battery like a misplaced screw. This usually happens because something is putting upward pressure on the screen. If there aren't any screws or other debris, take a look and make sure you have the speaker assembly in correctly.
If none of that works, try your old screen and see if it does the same thing. It very well could be a bad screen. If your old screen does the same thing, its possible that it could be a Touch IC issue.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It's possible that flex of the LCD is damaged and when you close the phone there is no connection between LCD and motherboard.
Puan 0
Yorum Ekle
Did you power down and disconnected the battery before changing? try a reboot..or put on the old screen an try to get it worked..
Puan 0
Yorum Ekle
Yanıtını ekle
kpf2274 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 89
