Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
I'm getting weird grey bars on top of screen
I recently replaced the microphone, charging section of an iPhone 6 4.7. Upon placing the screen back on, I received odd grey bars that extend to just below the clock and battery indicator. What could this be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Does the touch screen work at the moment? Like DC said try reseating the screen connectors, make sure to unplug battery before doing so.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Remove the screen, remove the connectors from the motherboard, sounds like one of the connectors is not attached correctly. When you connect those connectors they should make a click sounds just like putting Legos together. Put everything back together and you should be all good.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Does the screen sit properly in the case? What does the bar when you touch the glass with little (!!!) pressure of your finger?
Puan 0
Yorum Ekle
Yanıtını ekle
John Fairbanks sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 116
