Ana içeriğe geç
Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
959 Soru Tümünü görüntüle
Partial/Broken Display after closing the casing! iPod Classic 120GB
I replaced the battery in my ipod, a check to make sure all was working properly BEFORE closing up the casing revealed all was indeed working correctly.
But after closing the case, the display is now messed up, with part of the image missing and the rest broken into lines with kind of splatter marks across the screen.
Is this just a screen replacement job, a connection problem, or worse?
Any help greatly appreciated!
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Thanks. Yes - it looks like I may have squished the LCD on closing the case then.
tarafından
Nice, fine if you could mark my answer then. =)
tarafından
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
"Splatter marks"?
Sounds like a screen replacement. You probably cracked the LCD..
Google "cracked lcd" and see if your screen looks similar.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi Rousp
Thought I would just add (for everyone's info) that I received a new screen this morning.
Fitted it, and it works perfectly once again. Your prompt answer saved me a lot of time, I think I've marked your answer correctly, let me know if not.
Thanks
Puan 1
Yorumlar:
hi Tony. You should click on "accept answer".
tarafından
Hi Tony, glad to hear that. As bjoernen dk says you should click on "accept answer"
tarafından
Yorum Ekle
Yanıtını ekle
Tony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,243
