Will not switch to impact mode
The drill will not switch to impact when drilling
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 259
