Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair.
234 Soru Tümünü görüntüle
L2 and R2 /buttons 7 and 8 stuck after cleaning
Hi guys, I had a rather trashy looking but fully functional dualshock 4 - so I ordered a new shell, buttons, ribbon cable, etc from ebay to rebuild it. Basically everything is brand new except for the battery, motherboard, and usb board. Upon reassembly the controller works fine in the PS4 menus, but not at all in game, which lead me to suspect a stuck button. I plugged the controller into a windows 7 PC to test it, and in the controller settings *(where you test the joysticks and button assignments) it is saying buttons 7 and 8 are constantly pressed (L2 and R2 triggers) but the triggers respond OK on the analog testing axis. So while it appears the buttons are stuck, they aren't. any ideas? everything in the controller is new - new conductive film, new buttons, new rubber membranes, new shell, etc so I know it isn't a case of a dirty pad or contact. the L2/R2 springs are new as well, and everything feels like it is installed correctly.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I finally fixed my problem after a few weeks... Turns out I had ordered a new membrane from eBay and it turned out I had bought a bad one. I bought a new membrane and it worked fine. There are also a few different versions of the plastic membrane floating around. I bought one that was a different color (some are green some are blue) try a different membrane and it will probably fix the problem.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
My controller has R2 pressed on all times, I even removed the button and tested it on pc and it showed that it's still being pressed even when there's no rubber on the button. What's wrong with it please help me out.
Puan 0
Yorumlar:
Just in case anyone else Picks this one up...
I had this same problem and solved it by replacing the membrane/conductive film (£4 on ebay)
I couldn't see any damage on the old one but replacing it solved the problem.
tarafından
Yorum Ekle
Urgh, I hate that. It’s likely pinched by the shell. Just take it apart and put it back togeather again.
Puan 0
Yorum Ekle
Yanıtını ekle
Chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 85
Son 30 gün: 232
Her zaman: 2,876
