Ana içeriğe geç
Samsung NX Mini, Mart 2014'te piyasaya sürülen aynasız bir dijital fotoğraf makinesidir.
Zoom lens won't unlock
I have never drop this camera or taken off the lens after first putting it on. It's been about 9 months since I had this camera. The zoom lens won't unlock after rotating it like I normally would. This has been going on for 2 months. What can I do to fix it so the lens will unlock and I can use the camera again?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had this problem too. I took out the 3 outer screws on the back of the lens, one seemed loose, peeked in and decided there was no way I was going to fix this thing. Screwed it back on and the camera worked again. I suspect the screws were loose. Give that a try and see if it works.
I know I was about to throw my NX-mini out when I took the chance of unscrewing it. I wouldn't try to remove the back. Just try tightening the outer screws.
Update (10/27/2017)
Update: It stopped working again.
I had a technician at work take a look at it and he found that a ribbon cable in the lens sheared. He removed the cable and it works, kind of, in manual mode. I will be sending the lens to International Camera in Chicago to have it repaired.
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
Thanks Man. You really helped me.
tarafından
omg thank you so much this helped
tarafından
Its a really answer, thanks a lot brother
tarafından
Thank you! Great!
tarafından
My case is "kinda". I have to dismantle the lens, tighten the inner ("second layer") screws, re-set the main cable (which seemed to be totally fine), and it works again. But tighten the outer three screws did not work.
tarafından
Yorum Ekle
It works for me too. Just tighten the 3 outer screws, then on off once.
Puan 0
Yorum Ekle
You legend! Thank you!!! It worked. Might I add that I had to remove the three outer screws and put them back in before I was able to successfully fix it. So thank you for sharing your answer.
Puan 0
Yorum Ekle
Well you should go to near camera repair or hardware repair shop and give to some one who have the proper knowledge of how to fix this type camera.
Puan 0
Yorum Ekle
If you break the flex print it also unlocks again. Mine was likely already damaged and broke completely off in the last steps of re-assemble. Don't see any drawbacks but haven't used the camera much in the last 4 years due to this constant issue ;)
Puan 0
Yorum Ekle
Yanıtını ekle
katiexyooj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 36
Her zaman: 6,049
