*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
Bu iyi bir soru mu?
i have no service
Bu iyi bir soru mu?
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
Bu yanıt yardımcı oldu mu?
it's not firmware issue it's hardware
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 3,857
i need a answer for this question too . i have more then 5 iphones same issue
r.o0y tarafından
do you do microsoldering
Adrian Zymeri tarafından
Pls help me with my iPhone 6 plus Didn't show IMEI number
Oluwaloniglory tarafından
